dyno results : 234 hp and 400 nm
kassus
hi friends
this is the last dyno result of my thema 16vt serie II (185 hp official :top: ) i just use a manual boost controller to obtain 1.4 b peak turbo pressure, so as you can see with this turbo unit i cant go for more.....well with 234 i can say that im the shadow for my friends that drives s3 chipped of 242 hp and cupra r with 245 hp boths in the same dyno test :clap: but i wannnnnnt mooore!
next days i will install a bigggg t3 60/60 with them i hope obtain more of 250 hp easily :crazy:.....any experience with this kind of modifications on this old berline :D ???
regards
Do you really have à Lancia Thema turbo or a plane !!! [img]images/icones/icon15.gif[/img]
I hope you've improved the brakes on the car.
have you changed the pressure of fuel or upgraded the fuel pump?
kassus
hi
last year i installled brembo front rotors and ferodo pads and the car brake a little bit better, so now i want to change for metallic nipples.
riga i set fuel regulator of delta units, fitted to 3 b (original 2.8) as guy croft told me.
as you will know with preistoric le2jetronic i cant do nothing more and this is a shit, so the emissions are correct according to the dyno C02 results (not lean or rich)
marco68
quell'un peut fair la traduction SVP merci
le_makak
www.altavista.com pour la traduc vite fait mal fait
y'a des videos de ton "monstre" ?
kassus
benarvor
It doesn't work :ouin:
The link doesn't work...
Can you send it again please (and if you have some more pics of your car it would be great!)
Thanks in advance!
same for me... doesn't work...
